ax 2012 R3 job info log via email
  • 1.  ax 2012 R3 job info log via email
    Posted Apr 23, 2019 03:26 PM
    Hi developers,
    i need to send an email to a group of users, AFTER the job is executed, where i need to list lines from log in the email body.
    So here are two potential problems, where i can use some suggestions:
    1 - i can't add a task to run after the main task of the job, because the BatchHistory table (thats where the info lines live) is committed after the job has finished.
    2- there is an alert option, which would sent email to the user that the job is done, but then i would need to customize the body of the email message that was set up as a template for an alert - which i still cant figure out how...
    any ideas will be appreciated, thanks
    Pedja Nikodijevic
    Express Scripts Canada
    Mississauga
  • 2.  RE: ax 2012 R3 job info log via email
    Posted May 01, 2019 12:17 AM
    Hi Pedja,
    Can you tell why you think you need to customize the body of the email message? Are you missing some placeholders?
  • 3.  RE: ax 2012 R3 job info log via email
    Posted May 10, 2019 02:20 PM
    I would find this useful as well.
    We have a batch process that runs nightly, and the infolog from that process needs reviewed periodically.  Instead of having a sysadmin review it, it would be much better if the infolog results were sent directly to a front-line worker.
    (Note: This batch job always ends in an error state, but not every error in the log requires follow-up.)
    Daniel Zook
    Director of IT
    Lehman's
    Dalton OH
