Hi Deb,
There are several details to check, start with the inventory dimensions that are defined on the sales line against the dimensions of the on-hand received quantity.
Also, check that the inventory is available. It is possible that it is already reserved or marked against another order.
Was the purchase order generated from the sales order? If it was, then the SNs are already marked to the sales line.
Lastly, is the sales line still open (deliver remainder quantity = line quantity).
Duane
Duane Carlisle
SDC Consulting
Milton ON
Sent: Mar 17, 2021 05:33 PM
Subject: Serial number in sales order
I received a PO with 10 serial numbers and can see the SS# in inventory on hand, but when I go to the sales order I cannot choose the numbers available in stock.
things I have checked:
the use in sales order process is checked in my tracking dimension
I tried to use the update line, registration on the line of the SO but no SS available
Tried to use the 'register serial numbers' in the packing slip form but no SS numbers show up to sell from stock
What am I missing?
Deb Salyer
DS Erp Inc
Sarasota FL
941-351-2990
deb@dserpinc.com
