Vendor Bank Accounts
  • 1.  Vendor Bank Accounts
    Posted Oct 25, 2019 07:08 AM
    Edited by Gillian Leitch Oct 25, 2019 07:21 AM
    We use D365 F&O in the UK so hopefully what I see is the same but we call them suppliers instead of vendors.
    I need to only allow one single user access to add/edit the vendor bank accounts.  I tried to give her access via the privilege 'maintain supplier bank accounts' but the +new button is greyed out.  In fact, I can only seem to give her access if I make her a system admin so I am clearly missing some important role!
    Can anyone help advise which role or privilege or duty I need to look at here?  I obviously need to remove it from all other roles/users too to block their access.
    Many thanks.
    Gillian Leitch
    SLG Technology Limited
    Bridge of Weir
  • 2.  RE: Vendor Bank Accounts
    Posted Oct 29, 2019 08:32 AM
    I don't know which duty or privilege you need in order to limit that access. In our company we had a similar requirement so we used the new vendor "Supplier" approval workflows. User can only change the bank account after it goes through an approval from a manager.
    Vendor approval
    Juan Sebastian Grijalba
    Berkowitz Pollack Brant
    Miami
  • 3.  RE: Vendor Bank Accounts
    Posted Oct 29, 2019 12:34 PM
    Gillian,
    Do you see this privilege in your environment?
    Maintain vendor bank accounts
    Ian Gorman, PMP, MCSE
  • 4.  RE: Vendor Bank Accounts
    Posted Oct 31, 2019 07:24 AM
    Hi, yes, that is the privilege I mention in my post (we call it supplier rather than vendor).
    Gillian Leitch
    Bridge of Weir
  • 5.  RE: Vendor Bank Accounts
    Posted Oct 30, 2019 11:33 AM
    Gillian,
    The vendor bank account page is controlled by the VendBankAccounts menu item display. So a user would have to be assigned the following to be able to perform this task:
    - Create permission to the VendBankAccounts menu item display
    - Read permission VendTableListPage menu item display
    To find this, I recorded myself performing the steps using the task recorder and then analyzed it to find the menu items used during the process.
    You can either create a privilege specifically for this task,It looks like the following roles have access to do this process:
    If you have any questions feel free to reach out.
  • 6.  RE: Vendor Bank Accounts
    Posted Oct 31, 2019 07:27 AM
    Brilliant, thanks for this.  I hadn't realised we could control menu access in this way (although I had been wondering when you would create a privilege and what for!)  I will definitely give this a try now.
    Gillian Leitch
    Bridge of Weir
  • 7.  RE: Vendor Bank Accounts
    Posted Oct 31, 2019 10:11 AM
    Just to say that this worked so thank you so much!  Just need to ensure I remove the ability from the other roles now!!
    G
    Gillian Leitch
    Bridge of Weir
