Is there a way to generate D365FO reports and save them in Excel format to Onedrive, SharePoint, or a local network path? Is there any way to extract a report from D365 other than the standard output options: Screen, File, Printer, Email
We generate a large financial report that exceeds the maximum filesize our Exchange server can handle. (Greater than 35MB). We use a recurring batch job to generate this report every night. Using email output s not an option, nor is screen or printer. The File option does not work with batch (a message appears stating that it will not work). Selecting the Print Archive toggle will only output the report in PDF format. We require Excel output.
I would like to know if there is any other way to generate and extract this batched Excel report from D365. I'm open to ideas, however I would like the simplest possible solution if possible.
Thank you very much for your input.
Tim Khan
Application Support Analyst
DATA Communications Management Corp
Brampton ON
