Report/View for All Items in a Location?
  • 1.  Report/View for All Items in a Location?
    Posted 26 days ago
    Hi all,
    I have used these forums for a long time now, and have been to many AXUG events. I know this may seem very basic to some of you, but in preparing to set Cycle Count Thresholds, I was trying to figure out how to see all on-hand inventory for all of the locations in a warehouse.
    I have played around with the On-Hand menu items trying to get the location to populate but so far a report either times out or a grid won't populate the location and says 'unretrieved' in the column if I add it via personalization.
    Can anyone recommend the best/easiest way to see everything in a location that is on-hand?
    Scott Pollard
    Sunny Delight Beverages
    Cincinnati OH
  • 2.  RE: Report/View for All Items in a Location?
    Posted 25 days ago
    In the on-hand inquiry click on Inventory button > Dimensions display.  Select location from here.  Personalizing inventory dimensions does not work out very well as some entries are aggregated (that's why you get "Unretrieved")​ via dimension display.​
    Dimensions display
    Richard Wehmeyer
    PlayCore
    Chattanooga TN
  • 3.  RE: Report/View for All Items in a Location?
    Posted 25 days ago
    Thank you Richard, I appreciate it.
    Scott Pollard
    Cincinnati OH
  • 4.  RE: Report/View for All Items in a Location?
    Posted 25 days ago
    Hi Scott.  I concur with Richard.  Additionally, you can select Location when running On-Hand Inventory Report.
    Lori Holmes
    Hamamatsu Corporation
    Bridgewater, NJ
  • 5.  RE: Report/View for All Items in a Location?
    Posted 18 days ago
    Hi Scott, judging by the fact you're using Cycle count thresholds, you're using AX2012 R3 or D365FO Warehouse Management. There is a form called On-hand by location in Warehouse Management > Inquiries and Reports > On-hand by location.
    With the other on-hand forms, as others have mentioned, use the Dimensions display to show location when and where needed.
    eBECS Limited
    Atlanta GA
