Active document tables in AX 2012, whats the purpose
  • 1.  Active document tables in AX 2012, whats the purpose
    Posted 27 days ago
    Under Org Admin -> set up -> Document management -> Active document tables
    Whats the purpose of setting up, please advise
    Thanks and kind regards
  • 2.  RE: Active document tables in AX 2012, whats the purpose
    Posted 27 days ago
    I have used this to force document handling to work differently than out of the box defaults for two primary areas:
    1) Force document handling to only be available for certain tables (requires 'use active document tables' to be set to yes in parameters)
    2) Allow attachment editing/adding to posted documents (for example, GL entries)
    Note that for #2, you don't need to mark to use active document tables for it to work - you just mark the 'enable always' checkbox next to the table you are applying that setting to.​
    Shirley Adams
    AKA Enterprise Solutions
    New York NY
