AOT AX 2012 R3 Query using OR in the Relations
  • 1.  AOT AX 2012 R3 Query using OR in the Relations
    Posted Sep 26, 2019 08:31 AM
    I have a query I am converting from SQL to an AX AOT query.
    It has:
    LEFT OUTER JOIN INVENTDIMCOMBINATION IDC
    LEFT OUTER JOIN INVENTITEMGTIN UPC
                ON (UPC.INVENTDIMID = IDC.INVENTDIMID OR IDC.INVENTDIMID IS NULL)
    I know how to do the UPC.INVENTDIMID = IDC.INVENTDIMID section in the Relations for the outer join, but how do I handle the
    Probably easy to do, but I am not figuring out how to handle this.
    Dan Cantley
    Systems Analyst
    Bedrock Manufacturing Co, LLC
    Detroit MI
  • 2.  RE: AOT AX 2012 R3 Query using OR in the Relations
    Posted Sep 26, 2019 01:23 PM
    Ah - I need to do a UNION between the two kinds of data I pull up.  On one side of the union, I use ON (UPC.INVENTDIMID = IDC.INVENTDIMID) and have a range where IDC.INVENTDIMID  is not ''  -and on the other side I don't have a ON (UPC.INVENTDIMID = IDC.INVENTDIMID) and have a range where IDC.INVENTDIMID is ''
    It works in SQL - not to try it in AOT.
    Dan Cantley
    Systems Analyst
    Detroit MI
