Packing Slip reports with two designs
  • 1.  Packing Slip reports with two designs
    Posted May 28, 2020 10:41 PM
    Hi Experts,
    I have two report designs for packing slip which prints one after the other after packing slip is posted
    I want Note Type to display on Report design of Packing slip and Cert to display on CERT Report design
    Here is what i hvae done so far
    • Declared boolean isCert in SalesPackingSlipDP class decleration
    • In process report method
    if(objContract.parmDocumentTitle() == literalStr("@SYS11549"))
            isCert = false;
        else
            isCert = True;
    • In SetSalesPackingSlipDetailsTmp method
       if ((custFormletterDocument.DocuOnPackingSlip == DocuOnFormular::Line)
                 || (custFormletterDocument.DocuOnPackingSlip == DocuOnFormular::All))
                    If(isCert)
                        docuRefSearch = DocuRefSearch::newTypeIdAndRestriction(custPackingSlipTrans,"CERT",DocuRestriction::External);
                        salesPackingSlipTmp.Notes                   = Docu::concatDocuRefNotes(docuRefSearch);
                    else
                        docuRefSearch = DocuRefSearch::newTypeIdAndRestriction(custPackingSlipTrans,custFormletterDocument.DocuTypePackingSlip,DocuRestriction::External);
    The issue is output displays certification type notes in both reports and unable to switch between designs in code
    Debugged few times but was unable to get an idea where the designs are switching
    Kindly advice
    Shankar Iyer
  • 2.  RE: Packing Slip reports with two designs
    Posted Jun 01, 2020 08:12 AM
    Hi Shankar,
    I assume this is AX2012. Please check SalesPackingSlipController\output
    I don't have AX2012 installed right now, only D365FO, but idea is the same.
    Volodymyr Skorobogatko
    ENAVATE
    Englewood CO
