Purchase requisition to Purchase order data flow
  • 1.  Purchase requisition to Purchase order data flow
    Posted Jun 03, 2020 10:41 PM
    Hi All
    Its AX 2012, R3
    Noticed that some time when PR is converted to PO missing either delivery address or financial dimensions
    Although information is entered on PR level however when it converts to PO sometime not always either delivery address goes blank or dimension like department and location
    Any suggestion to start trouble shooting
    Thanks and kind regards
  • 2.  RE: Purchase requisition to Purchase order data flow
    Posted Jun 04, 2020 02:09 AM
    For this particular case where you do not see the delivery address and financial dimension been populated can you check the following:
    • Delivery address on the purchase requisition line details? Do you see the address for the selected warehouse on the purchase requisition line? Delivery address populates from the selected warehouse table.
    •  Can you check the vendor and item record you are using for this transaction and see what dimensions have been assigned on each record.
    • Have you populated the location on the purchase requisition line? Can you see if the inventory dimension location has been populated?
    Can you share some screenshots including the purchase requisition line and for  master data records if still you are experiencing the issue.
    Shilpi Thakur
    Dynact Consulting Ltd
