Setup of Non-Stock Service Item
  • 1.  Setup of Non-Stock Service Item
    Posted 12-04-2018 11:39 AM
    Hello All,
    We have been trying to configure the non-stock service items (These are the services that are to be delivered to our customers). We set the product type as service item, configured item model group : selected it to be un-stocked and allowed negative financial inventory. Once released, we tried to include that on Sales order and fulfill the order. We cannot fulfill as it prompts us to post the packing slip. We do not see any line items in the Post packing slip window. And the option of picking the items is disabled.
    Please let us know if we are doing anything wrong or missing any configuration.
    Thank you!
    Post Packing Slip
    Shubham Gaur
    Genetec
    Montreal QC
  • 2.  RE: Setup of Non-Stock Service Item
    Posted 12-04-2018 01:20 PM
    When you do your Packing slip posting, you need to select the quantity option "Picked quantity and not stocked products".    You should still be able to select this option and post for the service items only if you already packing slip updated your stocked products.
    Agility Business Solutions
  • 3.  RE: Setup of Non-Stock Service Item
    Posted 12-05-2018 08:17 AM
    I believe you can skip the packing slip and go straight to "generate invoice" if you change the Quantity setting there to "All".   If there are physical goods also shipping that you want to invoice together with the service item, then follow the advise of the previous comment to include the non-stock items on the packing slip.
    Lynn Kinsman
    Kodak Alaris Inc.
    Rochester NY
  • 4.  RE: Setup of Non-Stock Service Item
    Posted 12-11-2018 12:25 PM
    Agree with Colby, sounds like your Quantity selection is set to something else and ignore your service items. When set to "All" it would show all lines on the order whether item or service and if you select something like "Picked quantity and not stocked products" it would show any inventoried items that are picked plus all the service lines on the sales order that you can "ship."
    eBECS Limited
    Atlanta GA
  • 5.  RE: Setup of Non-Stock Service Item
    Posted 12-07-2018 05:12 PM
    Hi Shubham,
    Can you check if you have enabled the option Deduction requirements on the item model group? If so, you are required to first post the packing slip. If this is disabled, you can post the service item directly on the invoice.
