  • 1.  PO Total Amount of $0.00
    Posted 9 days ago
    I hope someone out there has some insight into why upon a Requisition converting to a PO, the "Total Amount" column on the main PO list is appearing as $0.00.
    The PO detail all looks correct, and hitting the "Sum" converts the $0.00 to the correct PO Total.  But this just started happening and clearly something is off.  Also, I heard from a User that she is unable to "Confirm" the PO, even after converting the $0.00 to the correct total.
    If anyone has thoughts, it would be much appreciated.  Running AX2012 R3.
    thanks- Wes
    Wes Mangum
    Washington DC
