add ISO-2 country code to shipcarriershippingrequest table for FedEx/UPS international shipping.
  • 1.  add ISO-2 country code to shipcarriershippingrequest table for FedEx/UPS international shipping.
    Posted 9 days ago
    Another reason that I hate the fact that Microsoft chose to go with ISO-3 vs ISO-2 country codes with AX 2012.. FedEx and UPS only support 2 character country codes. I am REALLY Surprised that I haven't been able to dig up more info, or more complaints, about it. Anyways, What I am trying to figure out how to do is insert the ISO-2 country code in to another column on the ShipCarrierShippingRequest Table that I can point fedex and ups to when trying to ship internationally. I would have to presume that there has to be some kind of translation / cross reference from the sales line table record using the "this.CountryRegionId" field?
    David Feifer
    Paul Reed Smith Guitars
    STEVENSVILLE MD
  • 2.  RE: add ISO-2 country code to shipcarriershippingrequest table for FedEx/UPS international shipping.
    Posted 9 days ago
    Depending on how your FedEx and UPS are set up, you could map the 3-character code to the 2-character code in the Integration Manager.  That is how FedEx and UPS set ours up.  If Microsoft changes the 3-digit code, you'll have to update the mapping.  Depending on your version, you may have an Organization administration tab > Setup > Address setup > Country/region and that shows the ISO 2-digit character code you could use to reference if you change the code in the ShipCarrier tables.  But seems easier just to do the mapping; then you don't have to worry much about Microsoft changing code.
    Richard Wu
    Bicon, LLC
    Boston MA
  • 3.  RE: add ISO-2 country code to shipcarriershippingrequest table for FedEx/UPS international shipping.
    Posted 9 days ago
    ​The ISO-2 code is in the countryregion table, for which countryregionid is the primary key. So you just have to join in that table, and show the other column.
    Tony Zeigler
  • 4.  RE: add ISO-2 country code to shipcarriershippingrequest table for FedEx/UPS international shipping.
    Posted 8 days ago
    As Tony mentioned below Dynamics contains both 3-digits ISO and 2-digits ISO country codes, they are also visible through the UI on the Country/Region form.
