difference between periodic journal and voucher template
  • 1.  difference between periodic journal and voucher template
    Posted 22 days ago
    Edited by Andy Walton 22 days ago
    Can someone provide some insight into the difference between a periodic journal and a voucher template?
    What is a scenario where one would use a voucher template instead of a periodic journal or are they essentially interchangeable as far as functionality is concerned.
    Thanks for your help!
    -Andy
    #UnifiedOperations
    Andy Walton
    Systems Analyst
    The Pokémon Company International
    Bellevue WA
  • 2.  RE: difference between periodic journal and voucher template
    Posted 22 days ago
    Try this: [Company]/General ledger/Periodic/Journals/Post Journals. In the form Add a filter with Journal type Field Criteria = Periodic
    Michael Gonzalez
    Account Executive
    Dynamics Resources
    Venon Hills IL
  • 3.  RE: difference between periodic journal and voucher template
    Posted 22 days ago
    A periodic journal cannot be posted directly. You have to use a general journal to retrieve the lines from a periodic journal. Then review it and post it directly or use periodic option.
    A periodic journal maintains a date which will be used to retrieve lines in a journal and will be updated according to the periodicity.
