Enterprise Portal for AX had a customer self-service portal but it was depreciated. However, you can transition AX 2012 to Dynamics 365. It is a complete suite of enterprise-based solutions and has a portal framework inbuilt into the system.
Talking about Dynamics 365 customer portal, it helps you manage orders, invoices, cases, documents, and customers from one defined space.
The best part is that you can customize it. For instance, if you want more features in the order management module besides tracking and viewing history, you can get it customized.
Knowledge Base, Forums, Appointment Management are a few of the other benefits you would avail.
Fidel Martin
CRMJetty
Santa Ana
Sent: Aug 18, 2020 11:12 AM
Subject: Customer Portal
Has anyone found a Customer Portal / eCommerce solution that works with AX?
Andrew Jaime
Director of Information Technology
Sokol and Company
Countryside IL
