Jeff,
If you want to keep the role access the same except change everything to Read access, then the only answer is to do that process manually. I can not think of a way to automate the process unless you wanted to write custom code to do so.
Sent: Apr 20, 2022 04:44 PM
Subject: Convert AX 2009 to Read Only access
We are about to go live on D365 F&O and want to put our AX 2009 environment in a "read only" state so that folks can still access it for historical look-ups but not change any data...is there a way to accomplish that without traversing the permissions tree for each role and changing all active nodes in the tree to "View" (we don't want to change any of the things users can ACCESS in their AX roles, but we do want to make everything they access read only).
Thanks in advance for your input!
Jeff Maynard
VP of Administration
Cope Plastics, Inc.
Alton IL
