Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
  • 1.  Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
    Posted Apr 23, 2019 12:51 PM
    When running Master scheduling(net change) I receive the below errors. I installed 2 recommended hotfixes from Microsoft and it seemed to help but the errors have started to appear again. We do not receive these errors message when we run a full regen. Anyone have any recommendations?
    Cannot create a record in Requirement transactions process filter (ReqProcessTransFilter). Scheduling process: XXXXXX, XXXXXXX.
    The record already exists.
    Cannot edit a record in Net requirements (ReqTrans).
    An update conflict occurred due to another user process deleting the record or changing one or more fields in the record.
    #UnifiedOperations
    #AX2012
    Michael Woods
  • 2.  RE: Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
    Posted Apr 24, 2019 09:07 AM
    Hi Michael -
    What is the environment version data (kernel and application) and what KBs were installed?
    Thanks....Dave
    Dave Phillips
    Microsoft
    Fargo ND
  • 3.  RE: Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
    Posted 29 days ago
    Hi Dave,
    Thanks for the response. This does not happen every time we run the Net change, its totally random. We have not implemented Net change(including below hotfixes) in our Prod environment yet only in our testing environment.
    Below are the details you requested:
    Kernel version: 6.3.6000.6803
    App Version: 6.3.1000.473
    Hotfixes
    KB 4019938 "Cannot edit a record" error for certain transactions entered after last full regen
    KB 4477601 Cannot create a record in Requirement transactions process filter (ReqProcessTransFilter). error occurs when running MRP in 'Net change' mode
    Let me know if you need any more information.
    Michael
    Michael Woods
    The Safariland Group
    Jacksonville FL
  • 4.  RE: Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
    Posted 25 days ago
    Hi Dave,
    Any idea if there are other hotfixes that we need to install?
    Michael
    Michael Woods
    Jacksonville FL
  • 5.  RE: Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
    Posted 25 days ago
    I've seen these errors pop up maybe once or twice in the past month. I haven't noticed any affect from them.
    Need I be concerned?
    Jon Gosche
    Manger Distribution Services
    Somagen Diagnostics Inc.
  • 6.  RE: Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
    Posted 25 days ago
    Hi Michael -
    Looks like the environment is AX2012 R3 CU8 released November 2014.  That date is important when you evaluate LCS bugs.  Any bug with a date after September, 2014 (adding a code freeze buffer), is worth considering.
    The earlier KB selection looks fine.  Are they destined for Live?
    You might look at this KB, https://fix.lcs.dynamics.com/Issue/Details?kb=4057156&bugId=3910157&dbType=0&qc=3a7dfd1f1b42f514f20fdfd8ffe7c9f9305ee9d7dbe9d5c938082145703e152b
    Released 12/20/2017
    KB 4057156 / Bug 3910157 (can be seen in the URL)
    This one too, https://fix.lcs.dynamics.com/Issue/Details?kb=4039914&bugId=3848259&dbType=0&qc=1321f83e5736c07aff0963c74a40faed70745e0bb4efb14b9425fccdeb836681
    Released 8/21/2017
    Also, the kernel is nearing one year old.  I would consider updating the kernel to a newer version to pick up the latest *scheduling*.dll's used by MRP.  The scheduling engine is now written in C#, so updates are delivered with kernels.
    See URL below for more on the Scheduling engine.
    https://docs.microsoft.com/en-us/dynamicsax-2012/developer/customizing-the-resource-scheduling-engine
    Kernels are also cumulative so don't be concerned about the name.  This one is fairly recent.
    https://fix.lcs.dynamics.com/Issue/Details?kb=4492733
    Kernels are a fairly quick install.  Let's get those in a test environment and see where you're at.
    Thanks....Dave
    Dave Phillips
    Microsoft
    Fargo ND
  • 7.  RE: Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
    Hi Dave,
    No luck with the hotfixes. We still receive the error and sometimes the job fails. The job seems to have a better success rate when we use less helpers.
    We are not moving forward with this process in production until we can get a clean run of results. Let me know if you have any more recommendations.
    Michael
    Michael Woods
    Jacksonville FL
  • 8.  RE: Master scheduling net change error (ReqProcessTransFilter, ReqTrans) #
    Hi Michael -
    At this point, we've installed the known KBs but still receive the errors.
    I would advice working with your partner and opening up a new ticket with MSFT.  Mention the installed KBs, kernel, and troubleshooting steps performed to date.
    Thanks....Dave
    Dave Phillips
    Microsoft
    Fargo ND
