FTP Files to upload in AX 2012
  • 1.  FTP Files to upload in AX 2012
    Posted Sep 30, 2019 03:18 PM
    HI All
    please can anyone share or advise the process of uploading FTP files in AX relating to General journal entry
    Thanks and kind regards
  • 2.  RE: FTP Files to upload in AX 2012
    Posted Oct 01, 2019 07:34 AM
    Hello Najeem,
    AX2012 does not natively support FTP as a file transport or mechanism for importing journal entries into AX.  In order to get journal entry into AX, you would typically setup an AIF inbound port.  The port would use the file system adapter and would monitor a location on the file system of the AOS server.  When a file appears in that directory, the port would then pick it up and import the file in as a general journal entry.​  The file would typically be an Excel/CSV template.  If you need to use FTP, you could either enable FTP on the AOS server and then have the AIF port monitor that FTP directory or you can have FTP running on a separate server and use a UNC path in the setup of the AIF port to point to the FTP server.
    Hope this helps.
    Ranny Grubb
    Ranny Grubb
    Dynamics AX Project Manager
    County of Roanoke
    Roanoke VA
  • 3.  RE: FTP Files to upload in AX 2012
    Posted Oct 02, 2019 12:17 PM
    ​Good Advice Ranny,
    I would encourage setting up FTP on a separate server, and letting the AOS contact it via UNC path. FTP is a weak point in network security and may take some effort to properly secure. The thought of having any leaks end up with access to an AOS server is a bit scary :)
    This is a blog with decent advice on securing FTP:
    FTP security best practices for the enterprise
    Tony Zeigler
