License Plate Controlled Inventory in Non LP Controlled Location
  • 1.  License Plate Controlled Inventory in Non LP Controlled Location
    Posted Jun 28, 2019 09:08 AM
    I have several warehouse locations that have a location profile that is not lp-controlled, but the inventory in that location has a license plate. I'm not sure how AX allowed this, it happened while temporarily moving inventory out so that the location profile could be changed.
    Now I can't move the inventory anywhere or count it down – I get an error message "License plate specified on a non-license plate controlled location."
    Has anyone run into this before, and if so how did you resolve the issue?
    Any advice is greatly appreciated. We are using AX 2012 R3 CU11 with Advanced Warehousing.
    Alison
    Alison Wright
    IT/Project Manager
    The Dodge Company
    Billerica MA
  • 2.  RE: License Plate Controlled Inventory in Non LP Controlled Location
    Posted Jun 28, 2019 11:32 AM
    Can you go into your location profile and change them to LP controlled just long enough to edit or move the inventory and then reset to non-LP controlled? It worked in D365FO when we just tested it. Our scenario was a location that is licence plate controlled, with inventory, and existing transactions. We were able to change the profile to non-LP controlled and move inventory and then change it back. Hopefully it is that simple and will work for you.
    Robin Finnell
    Continuous Improvement Coordinator
    Operations Lead - D365FO/MES Implementation
    Tillamook
  • 3.  RE: License Plate Controlled Inventory in Non LP Controlled Location
    Posted Jul 01, 2019 08:43 AM
    Hi Robin,
    Thanks for your reply and suggestion.  The system will let me move the inventory but not the LP so it thinks there are open transactions tied to the location and gives me an error when I try to change the profile ID.  I'm wondering if this is something that was resolved in a later version of AX.
    Alison
    Alison Wright
    IT/Project Manager
    The Dodge Company
    Billerica MA
