Change Management Query on Purchase Orders
  • 1.  Change Management Query on Purchase Orders
    Posted Jul 15, 2019 07:52 AM
    ​Good Day,
    The below error message is received when users are trying to confirm a purchase order.
    Changes to the document are only allowed in state Draft, because change management is activated.
    The solution provided to users is to select CTRL + F5 on the keyboard and that usually restores their last step, enabling them to confirm the purchase order successfully.
    We have had a few instances, whereby this does not work.  In order for the user to continue, we suggest, that a new purchase order be created, or request change, cancel delivery remainder on the problem lines, and recreate new lines on the purchase order.
    Is there another work around that can be used in order to bypass this error.
    I look forward to hearing from you.
    Erica Burns
    AX Consultant
    Omnia Group (PTY) LTD
    Johannesburg
  • 2.  RE: Change Management Query on Purchase Orders
    Posted Jul 15, 2019 11:56 AM
    Hi Erica -
    What is the version?
    Thanks....Dave
    Dave Phillips
    Microsoft
    Fargo ND
  • 3.  RE: Change Management Query on Purchase Orders
    Posted Jul 15, 2019 12:01 PM
    Thank you for your response.
    We are on AX 2012 R3 CU12.
    Kind Regards,
    Erica Burns
    AX Support
    OmniTECH
    Omnia Group (Pty) Ltd
    T:         +27 11 799 6278
    E:         erica.burns@omnia.co.za
    Web:    http://www.omnia.co.za/
    image001.jpg@01CFB634.C2F64DB0
  • 4.  RE: Change Management Query on Purchase Orders
    Posted Jul 15, 2019 12:35 PM
    Hi Erica -
    I did not find existing bugs in R3 CU12 or later.
    If you can consistently repro this issue, you should take a small AX Trace (Tracing exists in the AOT) and then use Trace Parser to read the file.  May need a developer.
    https://docs.microsoft.com/en-us/dynamicsax-2012/appuser-itpro/install-the-trace-parser
    https://community.dynamics.com/ax/b/exploremicrosoftdynamicax/posts/microsoft-dynamics-ax-2012-utilities-trace-parser
    https://blogs.msdn.microsoft.com/axinthefield/dynamics-ax-tracing-part-1/ (series created by Tom Stumpf right up here in Fargo).
    Some tips to take a good Trace.
    1. Short as possible.  Start the Trace right before the error.  Stop right after the error.
    2. No other users in the environment.  No Batches, integrations, etc. running.
    3. Review the Trace file in the same environment so custom code is fully exposed.
    Many sites get some error in LIVE, copy to TEST, and do the Tracing in TEST where they can control everything.  Trace Parser installed in TEST.
    Thanks....Dave
    Dave Phillips
    Microsoft
    Fargo ND
