Management reporter time out issue
  • 1.  Management reporter time out issue
    Hi All
    We are on AX 2012 R3, Management reportor specially for where block  "Tree" reporting is set up its time out or running like half an hour to produce a report
    Last month same report was fine and was not taking that long to run
    Any suggestion, please advise
    Thanks and kind regards
  • 2.  RE: Management reporter time out issue
    Hello, I would recommend:
    • Increase RAM memory on server (see install prereqs pdf file attached)
    • Sometimes split the three MgtRpt components onto separate servers (process service, application service, data mart)
    • You may change timeout settings (see install config pdf file attached) in config files on server
    • Shy away from transaction detail with many monthly periodic columns unless truly needed
    • Be on latest MR 2012 CU16 release
    • I would be glad to complimentary look at report layout and server config via GoToMeeting
    • Hope to see you and others at the regular Mgt Reporter trainings we do regularly for AXUG so look to their Academy Learning line or email anytime for questions/tips
    Derek Krebs
    Sr Consultant
    MSX Group
    derek.krebs@msxgroup.com
    Attachment(s)
  • 3.  RE: Management reporter time out issue
    Posted 10 days ago
    Thanks a lot Derek, you are the best
    3rd option : You may change timeout settings, helped to fix the issue. Now reports runs in seconds
    Thank you so much for always being here to assist with MR
    Please when are you planning to conduct MR technical session like Data Mart refresh and MR versions knowledge based training, how to upgrade to to CPU16
    Also want to share that we are on CU8  2.1.8991.0 which doesnt support AX 2012 R3 Ledger but it supported
