Hi Mark,
Signatures printed on generated documents such as invoices and orders are not OOTB feature in AX 2012/D365FO - except for the Check report and perhaps some others I'm not aware of. You can achieve it only through customization of these documents.
However, you can easily print signatures on any document by using a reporting tool such as
Docentric AX, which enables you to design business documents in MS Word and place a signature bound to a dynamic image in the document data source anywhere in the document template.
You can also watch
this video to learn how Docentric supports electronic signatures as well as signature appearances on the signed PDF documents.
Kind regards,
Ana
Ana Gligorijevic
Software Architect
Docentric
Sent: May 02, 2019 01:23 PM
Subject: Electronic Signatures
Hello out there!
Can someone guide how to implement electronic signatures? Can they be put on any printed document or is it restricted to only a few in standard AX?
Thanks!
#AX2012
#Beginner
Mark Yankovich
