Invoice journal template
Jump to Best Answer
  • 1.  Invoice journal template
    Posted Jan 29, 2019 09:38 AM
    Is it possible to delete an "Invoice journal template" in D365?
    If yes, please let me know how.
    If no, why Microsoft didn't think about that?
    Thank
    Richard
    Richard Malouin CPA, CGA
    PSP Investments
  • 2.  RE: Invoice journal template
    Posted Jan 30, 2019 09:16 AM
    Hi Richard,
    Can you explain what you mean with an "Invoice journal template"?
  • 3.  RE: Invoice journal template
    Posted Jan 30, 2019 10:07 AM
    Hi André,
    Template: Invoice entry that you will use on a regular basis and you will use the same Ledger and vendor each time. Description, date and amount should change.
    And it's not a "periodic entry".
    PSP Investments
  • 4.  RE: Invoice journal template
    Posted Jan 30, 2019 12:07 PM
    Hi Richard,
    Which exact menu path are you using to create or view your templates?
  • 5.  RE: Invoice journal template
    Posted Jan 30, 2019 04:44 PM
    Hi André,
    Once in the Batch, and all lines entries created, i click on Function/Save voucher template. See attachment.
    Richard
    Senior analyst
    PSP Investments
  • 6.  RE: Invoice journal template
    Best Answer
    Posted Jan 30, 2019 04:59 PM
    Hi Richard,
    Thanks for the clarification. I'm aware of the voucher template functionality, but got confused.
    There is actually one option to delete the voucher templates. When you open the Select voucher template form from the sub menu as shared above by you, you are able to mainly select templates. If you select a certain template (upper part of the form), you can use the key combination ALT+F9 or ALT+DEL to delete a template.
  • 7.  RE: Invoice journal template
    Hi Richard,
    Select the voucher template header (or line) and use "ALT+Del" and that should get rid of it.
    Cheers
    Phil
    Phil Dawson
    Data#3 Limited
    Toowong
