Enterprise Portal
  • 1.  Enterprise Portal
    Posted Jan 30, 2018 09:35 AM
    ​We use Enterprise Portal with AX2012.  Our vendor's complain that it is extremely slow and cumbersome to use.  Specifically with the RFQ.  We have talked with Premier and our network team and have run out of solutions to try.  Does anyone use the portal?  Have you had similar experiences or better experience?
    Kenny Prince
    Leggett & Platt, Inc.
    Carthage MO
  • 2.  RE: Enterprise Portal
    Posted Jan 31, 2018 08:08 AM
    ​We had similar issues but it was related to a different 'module'. However, we had some customization done within the time sheet that was related to inventory. So employees could enter inventory on the timesheet that was used with a bunch of other special fields indicating location, projects, etc etc. Some of the code was re done and the speed of this was astronomically faster. My point, was there any customizations done within EP? do you have un necessary things turned on that don't get used?
    Alex Bailey
    ATMC
  • 3.  RE: Enterprise Portal
    Posted Jan 31, 2018 08:31 AM
    We use EP extensively though a different module(actually an ISV Custom module).
    As the other poster mentioned the cumbersome part really is a customization exercise to ensure that the EP forms are optimized for the desired process.
    While I would not describe our EP as fast,  it is acceptable.  We have had to make significant infrastructure and set-up investments to get EP to work acceptably.  In our case this means:
    -Dedicated AOS for EP connections
    -Dedicated SQL server for SharePoint/EP
    -Multiple IIS Servers to use as EP Front End
    -Load Balancer in front of the IIS Servers
    -Optimization efforts on the Routers/Firewalls to ensure that communications between the servers is efficient.
    It is worth noting that if you plan on migrating to D365 For Operations and Finance Enterprise Edition,   then a separate EP is no longer needed as the entire application is web based.
    Corey Vantilborg
    ERP Analyst
    Tigercat International Inc.
    Brantford ON
  • 4.  RE: Enterprise Portal
    Posted Jun 04, 2019 12:24 PM
    Hi Corey,
    we are having performance issues with EP, we use both timesheet reporting expense reports. can i know how may web users you have in your peak time on your system..?
    We have 20 users during peak time
    mounika.narne@gmail.com mounika.narne@gmail.com
    ERP Developer/AX Specialist
    Bethesda MD
  • 5.  RE: Enterprise Portal
    Posted Jun 05, 2019 08:07 AM
    I think our concurrent user count would be similar to that.
    What does your EP architecture look like?
    Corey Vantilborg
    ERP Analyst
    Brantford ON
  • 6.  RE: Enterprise Portal
    Posted Jun 05, 2019 01:26 PM
    Edited by mounika.narne@gmail.com mounika.narne@gmail.com Jun 05, 2019 01:26 PM
    @Corey Vantilborg Thank you for responding. Appreciate it
    I am not an admin person, so trying to put as best as I can .
    • We have three AOS servers, out of which one is for batch processing
    • EP service is running on its Dedicated server. The configuration is pointing to both AOS servers
    • Two databases  servers, one is for replication.
    • one BI server exclusively for reporting.
    Enviva
    Bethesda MD
  • 7.  RE: Enterprise Portal
    Posted Jun 06, 2019 12:49 PM
    I have worked with over 100 AX customers over the past several years, assisting with general AX optimization and BI, and I have yet to find an AX customer who is effectively using EP (except perhaps Corey below - but this appears to be more of an ISV solution).  EP is based on SharePoint technology and it is extremely cumbersome from an integration perspective.  I am aware of several clients who went down the EP path, only to "shelf" the initiative because of either performance issues, inflexibility or general lack of feature/functionality.  Also, finding resources to work on it is difficult, as you need to know both Sharepoint, as well as X++ (the underlying code base for AX2009 and 2012) - very rare.  Its a rat hole - and Microsoft themselves acquiesced and the framework was abandoned in the next release with D365.  I would suggest you limit your investments in EP.
    Gina Pabalan
    Blue Kite
    Independent Senior BI Advisor | Program Manager | Microsoft Dynamics
    gina.pabalan@ibluekite.com
