Canada - Vancouver, BC - AX
Jun Chapter Meeting Topic # 2
  • 1.  Jun Chapter Meeting Topic # 2
    Posted Jun 06, 2019 01:38 AM
    Please join us on June 27th to hear from Angad Soni who will be discussing Data and Analytics: How data and analytics can reduce risk in D365 F&O Projects.
    Historically most ERPs projects fail or are delayed due to an overwhelming amount of change required both from a technical but also a functional perspective. Leveraging data and analytics to reduce the overall risk of the project and improve the quality of your implementation. This can be achieved via data and analytics due to the following reasons:
    • Reduces customizations to support reporting, reporting hierarchies for roll-ups, multi-currency and historical storage of data by allowing the data and analytics environment to support that natively
    • Improves the quality of your data migration by allowing the transformed, cleansed and curated data sourced from the data and analytics and/or data hub repository
    • Integrations complexity reduces when using the data hub as an intermediary for point-to-point interfaces and using a control database for business logic and data transformation
    Angad is currently a Solution Principal at Hitachi Solutions, with national responsibility across Canada. Angad is a passionate, high-energy data expert whose experience spans various technical roles and industries. Since joining Hitachi, he has been devoted to innovating and leading within the Azure space across all projects and technology components, including D365 F&O & CE.
    You can register for the event here - Canada (Vancouver, BC) - AX - Dynamics AX User Group
    Axug remove preview
    View this on Axug >
    Look forward to seeing you there.
    Christopher Ho Yee
    Altius Consulting
    Richmond BC
