Are you searching for effective manual methods to import multiple MSG files into Outlook PST? If yes, then you need to go through this article that explains the manual techniques to
convert multiple MSG files to PST. It will also explain the possible reasons for the conversion of the MSG files to Outlook PST. Here, you will find out the hand-operated methods to import MSG files into Outlook by using:
- Drag and Drop Method.
- Copy and Paste Method.
The detailed step-by-step procedure is explained in this article. You can refer to it for importing multiple MSG files into Outlook PST. However, if you are not sure about the security of your file data then this article also explained a prominent tool for this conversion. You can try its free demo version to analyze the performance.
Mike Foster
Software Developer
San Jose CA-95134, USA
