US - New York NYC AX
How to convert NSF File into MSG format
  • 1.  How to convert NSF File into MSG format
    Posted Jul 23, 2021 08:39 AM
    To easily convert NSF File into MSG format supported by MS Outlook, choose a professional solution MailsDaddy NSF to MSG Converter tool. The software helps to successfully convert multiple NSF files to MSG file format at a single time. It is also compatible to transfer Lotus Notes contacts in .csv and calendars in .ics format. The application offers users to migrate any size of NSF file into MSG format without any file size restrictions. This unique solution offers an advanced filter option to export only selective NSF data into MSG format. The software smoothly working with NSF files of all IBM Lotus Notes editions.
    More Info- https://www.mailsdaddy.com/nsf-to-msg-converter/
    Somendra Singh
    MailsDaddy
  • 2.  RE: How to convert NSF File into MSG format
    Posted Aug 11, 2021 05:21 AM
    You can try Softaken NSF to MSG Converter software is a great designed tool that export NSF data to MSG format. By this utility, the users can migrate and access large NSF items such as emails, contacts, notes, journals, tasks, etc. in an effortless manner. The application works effectively with all editions of MS Outlook including Outlook 2003, 2007, 2010, 2013, 2016, 2019, etc.
    Carter Willson
    aadsadads
