US - New York NYC AX
  • 1.  Best method to import Lotus Notes NSF files into Outlook
    Posted Jul 22, 2021 06:42 AM
    Using Mailsaddy NSF to PST Converter which is very Effective software to Export NSF to PST Outlook. This tool to Restore the converted NSF file into various formats such as EML, EMLx, MSG, HTML, MHTML, and MBOX file format then convert Lotus Notes to Outlook format including Calendar, Email, Journal, Tasks, and Contact, etc. The NSF to PST converter imports NSF files directly to the Exchange server and Office 365 without installing MS Outlook.
    More Info- https://www.mailsdaddy.com/nsf-to-pst-converter/
    Somendra Singh
    MailsDaddy
  • 2.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Aug 12, 2021 01:43 PM
    Here is the best solution to convert NSF to pst in outlook 2016 which additionally offers user to migrate NSF items of MS outlook and transfers the recovered items like emails, chats, tasks, notes, journals, appointments to several different file formats. Along with NSF to PST converter tool crack software smoothly split large PST files in small PST file after conversion from NSF to PST. Refer:- https://www.softakensoftware.com/blog/ways-to-migrate-nsf-files-into-pst-files.html
    Carter Willson
    aadsadads
  • 3.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Aug 24, 2021 04:32 AM
    There are two ways to convert Lotus Notes backed NSF files; the first is the Manual method, and the second is the software solution. But due to many drawbacks in a manual process, such as it does not support PST export, providing bulk migrations, and does not allow to migrate Office 365. Moreover, you can split the extensive NSF data according to your choice, even does not allow you to choose the specific mail items to export as such many more drawbacks you can face in the manual method. Luckily, Stellar Converter for NSF supports all such features, and you get converted PST without any hassle and putting extra effort. For detail about the Stellar Converter for NSF, I suggest you check the website and test the demo version https://www.stellarinfo.com/email-repair/nsf-pst-converter.php.
    Trisha Agarwal
    Stellar Information Private Limited
  • 4.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Oct 28, 2021 04:39 AM
    I recommend using this Datavare NSF to PST Converter Free to convert NSF files to PST, which includes all email properties such as emails, calendars, tasks, notes, journals, and contacts (names.nsf). Users can save converted NSF files to PST, MSG, EML, EMLx, and MBOX files. It GUI is a basic and user-friendly interface that allows even non-technical people to simply operate the software. You should evaluate its features and functionality using the free demo version.
    jenny fotagi
    2365417987
  • 5.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Nov 26, 2021 07:18 AM
    The help of Lotus Notes to PST Converter software allows users to convert unlimited Lotus Notes.NSF files. It successfully exports Lotus Notes to MS Outlook and converts NSF to PST with text, attachments, folders, and subfolders, Message properties like to, from, cc, bcc, sent/received dates and times, Calendar items, Task items, Encrypted email, and attachments.
    The advanced tool can easily convert NSF files to Multiple files formats such as PST, MSG, EML, EMLX, and HTML file format. It is fully capable to supports all the Lotus Notes Versions of 10.0.1, 9.0, 8.5, 8.0.2, 7.0, and etc.
    Visit here:- https://www.gaintools.com/nsf/
    Harrison Scott
    asdsdsdsd
  • 6.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Feb 17, 2022 07:09 AM
    Try SysCurve NSF to PST Converter. It is one of the best tools that quickly change the Lotus Notes NSF database to Outlook supported PST file format. The software also allows users to change NSF to EML, MBOX, MSG, and other formats. Using this tool, you can also perform Lotus Notes to Office 365 migration.
    To know more about this tool, visit: https://www.syscurve.com/blog/how-to-convert-lotus-notes-to-outlook.html
    Deepak Bisht
    SysCurve Software
  • 7.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Feb 17, 2022 07:17 AM
    To convert Lotus Notes to Outlook, you can try manual or third-party solutions. Both are very helpful. However, the manual solution requires technical expertise for proper execution. If you do not have a technical background, then use SysCurve NSF to PST Converter. Using this tool, you can easily perform this conversion.
    To know more, visit: https://www.syscurve.com/nsf-to-pst-converter.html
    For manual solution, visit: https://www.syscurve.com/blog/how-to-convert-lotus-notes-to-outlook.html
    Deepak Bisht
    SysCurve Software
  • 8.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Feb 17, 2022 07:51 AM
    Everyone knows that the manual solution has some limitations that affect the migration process badly. So, to solve all those drawbacks here, we come up with an automated solution named "CubexSoft NSF to PST Converter" software. With the help of this software, a user can easily implement the migration process without taking any technical person's help. Moreover, it provides an understandable and easy-to-use interface so, a non-technical user can also use this software. Mainly, this automated tool is designed with advanced features and functionalities.
    Read More: Lotus Notes to Outlook
    Maria Hirthe
    CubexSoft Tools Pvt. Ltd.
  • 9.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Feb 26, 2022 04:41 AM
    One of the reliable methods to convert NSF to PST Without Lotus Notes is by opting for a reliable professional tool that will help you to accomplish this task by maintaining high data security. In this regard, I have used the Cigati NSF to PST Converter which is an extensive utility to convert your NSF files into PST. Additionally, this software has an interactive user interface that is compatible with both technical and non-technical users. You can also try its free trial version to analyze its performance.
    Travis Wilson
    Software Developer|Technical Consultant
    California US
  • 10.  RE: Best method to import Lotus Notes NSF files into Outlook
    Posted Apr 13, 2022 12:53 AM
    The best method to convert Lotus Notes to Outlook is by using an advanced tool named as DRS NSF to PST Converter . It is an advanced tool to transfer Lotus Notes files into multiple other file formats and email clients. The software has the capability to convert your data without any change in your original  data structure. The application is convenient to use both for technical and non technical users. You can easily install this NSF to PST Converter and convert 50 emails per folder for free.
    To know more, watch this video -
    alice murphy
    DRS
    California
