There are many methods to Convert NSF to PST. You can convert NSF files by the manual or tool-based method. if you want to convert NSF file with manual method so you can follow some steps which are listed below:-
Step 1-
Exporting mails from Lotus notes.
- Start the Lotus Notes application on your PC.
- Choose the Export option from the File menu.
- Choose Comma Separated Value for your file from the drop-down menu.
- On the next screen, click Export.
- To export the CSV files, click OK.
- Now, change the extension of the backup file to .csv.
- Now let's look at how to import CSV files into Outlook.
The above steps will allow you to successfully download your Lotus Notes email in CSV format. Unfortunately, the entire mailbox cannot be downloaded in one session. Each email has to be saved separately. Follow the steps below to use Microsoft Outlook.
Step 2-
Open the CSV files in Outlook.
- Launch Outlook on your PC.
- Click the File button in the navigation bar.
- After that, select Open & Export from the menu bar, then select Import/Export from the drop-down menu.
- Select Import from another program or file in the Import and Export Wizard. Then press the Next button.
- Then press the Next button after selecting Comma Separated Values.
- Select the preferred location for the folder by clicking Browse, then Next.
- Select the folder you wish to import from in Outlook, then click the Next button.
- Finally, click Finish to complete the procedure.
Manually converting Lotus Notes to Outlook is simple and free. Although the process is time-consuming, data loss can occur if a large volume of data is being transferred. There are many professional tools in the market to convert NSF to PST but I would like to suggest DRS
NSF to PST Converter which is very effective for the users. with this tool, you can convert NSF files into various file formats. there are many advanced features in this tool. Users also can use the free demo version.
Hazel Cob
DRS Softech
Noida
Sent: Mar 15, 2022 02:13 AM
Subject: NSF to PST Converter
Weeom NSF to PST Converter tool works very fast to convert NSF files into PST file format. The tool is also experienced in NSF to EML and MSG files. It is very quick and smooth to use. The software has an advanced option for email translation and folder mapping. The software provides the facility to filter the data as per the requirements of the users.
Features of Weeom NSF to PST Converter
- The software converts multiple NSF files to PST file format in one go.
- Splitter option split Resultant PST files according to file size.
- users can download a free version of the software for exploration.
Visit for More Info : Lotus Notes to Office 365 Migration Tool
Priya Tomar
Weeom solution
Dehradun
