Australia - National - AX
Costprice fluctuations
  • 1.  Costprice fluctuations
    Posted Oct 05, 2020 08:35 PM
    we're currently running AX2012 R3CU10 with weighted average turned on.
    We've seen some big quantities coming through and therefore these fluctuations stands out.
    I'm a little at a loss where these originates from and would like to see if someone in here have an idea?
    CostPrice1
    First transaction after inventory closure the cost price for the sales order picked up a cost price different from the closing cost price.
    How does that make sense?
    CostPrice2
    After I did inventory closure last month end it calculated a proper cost price.
    We had a couple of purchase order received which calculated ok.
    We then did a Quarantine transaction where we use the scanner and moved the item from it's location into damaged/blocking location.
    I'm not sure what happened there but it seems that it grabbed a cost price out of the blue $126.60.
    When they do these transaction on the scanner, they don't enter any cost price, do you know where AX calculates the cost price from?
    And once calculated it seems to keep that cost price on future sales orders as well, as you can see below, how can that be?
    Once month end runs this will rectify but in the mean time the system reports margins all wrong. Which is a huge issue.
    thanks
    Soren
    Soren Normann Rasmussen
    SSS Australia
    Murarrie
  • 2.  RE: Costprice fluctuations
    Posted Feb 25, 2021 12:34 AM
    Hi Soren
    There is no denying that AX/D365 inv costing is complex, but in my experience it can always be analysed and explained. Sadly, that can take hours to do, depending on the complexity of your items transactions.
    Did you ever get to understanding the data, or is it still an issue for you ?
    Geoff McMaster
    geoff mcmaster
    Premier Field Engineer
    Microsoft
