  • 1.  PowerApps with D365 Finance and Operations
    Posted Jul 21, 2020 04:58 PM
    I created a simple PowerApp to return a list of our F&O vendors with search capability. I want to share the app with a controlled list of coworkers who simply need an updated vendor list at times.  It appears that in order to use the PowerApp, a coworker has to be a user in F&O. Is there any way around this? Can I some how embed a log in to the PowerApp so that it bypasses the need to be an F&O user?
    Julie Husted
    Financial Application Manager
    ALAS Ltd.
    Chicago IL
  • 2.  RE: PowerApps with D365 Finance and Operations
    Posted Jul 27, 2020 08:19 AM
    Unfortunately if you build the PowerApp in top of a D365 F&O data entity or using the D365 F&O connector then consumers need to have access to D365 F&O source data in order consume the app. As a work around, and for your purposes this might work, then I will built a flow to export the vendor list into a SharePoint list, have that flow update the list on a schedule and then build the app in top of the SharePoint list. Now you can control all the security using SharePoint and the office 365 license should cover all users.
    Juan Sebastian Grijalba
    Berkowitz Pollack Brant
    Miami
  • 3.  RE: PowerApps with D365 Finance and Operations
    Posted Jul 28, 2020 09:23 AM
    HiJulie,
    Take a look into using Data Integrator and import the Vendors from Finance into the Common Data Service.
    The docs here should get you started.
    https://docs.microsoft.com/en-us/power-platform/admin/data-integrator
    Mike
    Mike Hammons
    AKA Enterprise Solutions
    GA
