Check the reservation value on the line. As another poster mentioned, it could be picking up a value from the item as well. I believe if it has, the line will end up with a setting of automatic.
If the line is set to automatic, you can check the item settings, and the header setting, to see which one could be causing the issue.
If the line is not set to automatic, it may be time to get a programmer to debug - as I suspect you have some custom code in place.
Good luck tracking it down :)
Tony Zeigler
Sent: Nov 17, 2019 12:15 AM
Subject: Item Reservation in Sales Order creation
Hi Tony,
Thanks for the reply,
Actually I created a new sales order after changed the settings as Manual in Accounts receivable parameters but still while click Save it's showing Auto reservation form.
Abrar Ahamed
Arla Foods - Saudi Arabia
Sent: Nov 15, 2019 11:32 AM
The module parameter is technically just a default onto your sales order header, and from there to the lines.
Thus - on an order your testing, you'll want to make sure the line value for reservation is set to Manual as you test. If you were testing with an order created prior to your setting of the module parameter, it will likely still have it's header value set to Automatic, thus causing your lines to get set that way regardless of the module parameter.
Tony Zeigler
Sent: Nov 14, 2019 07:51 AM
Hi Andre,
Thanks for Reply
I Changed sales default values reservation settings in Account receivable parameters as Manual(Find the attachment) but still, once I entered the sales order line while click save auto reservation form(Find the attachment) showing then after click OK it's reserving again.
is there any way to avoid that auto reservation form?
Abrar Ahamed
Sent: Nov 14, 2019 05:58 AM
Hi Abrar,
On the Accounts receivable parameters there is a setting for the reservation to be automatic or manual.
Sent: Nov 14, 2019 01:24 AM
Can you guide us about create a sales order without reserve the item?
Actually we creating sales order and delivery is after 1 month but while creating sales order itself it is reserving the item it will lead to other current documents not posting due to missing inventory.
#Focus-D365UG/AXUG
#Sales
#Functional
Abrar Ahamed
