WBS Templates requiring Line property error
  • 1.  WBS Templates requiring Line property error
    Posted 24 days ago
    We're having an issue with our Project WBS templates in one legal entity whereby it is requiring a Line property value to be filled in. However, when we select a value it does not allow for a value to be saved.
    If we attempt to publish a WBS it will fail due to this. In our other legal entities, this is not required.
    We have reviewed the configuration between companies and cannot seem to find the difference. Has anyone encountered this before and know what configuration we might be activated?
    Appreciate any insights.
    Christopher Ho Yee
    Altius Consulting
    Richmond BC
  • 2.  RE: WBS Templates requiring Line property error
    Posted 23 days ago
    Hi Christoper,
    It may be that there is a line property missing somewhere in the details of your cost estimate. Have you tried changing your view to "Cost Estimates" and verifying that all of the line items under each WBS task have valid line properties?
    Kind Regards,
    Marlene
    Marlene Baldwin
    Sr Consultant
    Stoneridge Software
    Fargo
  • 3.  RE: WBS Templates requiring Line property error
    Posted 23 days ago
    Thanks Marlene! That did the trick.
    Cheers,
    Chris
    Christopher Ho Yee
    Altius Consulting
    Richmond BC
  • 4.  RE: WBS Templates requiring Line property error
    Posted 19 days ago
    Glad it worked!
    Marlene Baldwin
    Sr Consultant
    Stoneridge Software
    Fargo
