unable to acquire Fixed asset
  • 1.  unable to acquire Fixed asset
    Posted Apr 03, 2020 10:55 PM
    Hi All
    While running FA acquisition, keep getting below error message for only fixed asset, However for other asset able to acquire
    Microsoft.Dynamics.Ax.Xpp.InfoException: Exception of type 'Microsoft.Dynamics.Ax.Xpp.InfoException' was thrown.
    at Microsoft.Dynamics.Ax.MSIL.Interop.throwException(Int32 ExceptionValue)
    at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.callReturn(Int32 rc, interpret* ip)
    at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.CallStatic(String className, String methodName, Object[] parameters, Type[] types, Object[] varargs, Type[] varargsTypes)
    at Microsoft.Dynamics.Ax.Xpp.XppObjectBase.StaticCall(String className, String methodName, Object[] parameters, Type[] types, Object[] varargs)
    at Dynamics.Ax.Application.Debug.assert(Boolean expression)
    at Dynamics.Ax.Application.AssetProposalAcquisition.Run() in AssetProposalAcquisition.run.xpp:line 215
    at Dynamics.Ax.Application.AssetProposal.runIL(Object[] _parameters) in AssetProposal.runIL.xpp:line 31
    at AssetProposal::runIL(Object[] )
    at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
    at Dynamics.Ax.Application.SysDictClass.invokeStaticMethod(Object[] _params) in SysDictClass.invokeStaticMethod.xpp:line 26
    at SysDictClass::invokeStaticMethod(Object[] )
    at Microsoft.Dynamics.Ax.Xpp.PredefinedFunctions.runAsInvoke(String className, String staticMethodName, Object[] parms, Object[]& exportInfolog)
    Please advise
    Thanks and knd regards
  • 2.  RE: unable to acquire Fixed asset
    Posted Apr 10, 2020 03:20 AM
    Hi Najeem,
    It seems that system is trying to find the invoice lines related to the transaction and is not able to. It will be required to debug the code and find whether there is an issue with generating invoice. The system is showing trace log, but the actual error is not visible.
    Can you please provide the Dynamics AX version detail? This will help with finding the actual error. There was a known bug in AX 2012 related to it and a hotfix is also available to resolve the issue.
    This answer is provided by Krupa Shar, Sr. Software Engineer, Dynamics 365FO, Synoptek.
    Nandita Nityanandam
    Marketing Head
    Synoptek
    Oakbrook Terrace IL
  • 3.  RE: unable to acquire Fixed asset
    Posted Apr 10, 2020 07:45 AM
    you should also check on FA books
    and in Fixed assets parameters check Allow asset acquisition from Purchasing is allowed
    if still having issue could share the setup books and error screen
    Rahul Mohta
    Advisor - D365FO
    Real Dynamics
