Atlas 6.1 Filtering
  • 1.  Atlas 6.1 Filtering
    Posted 19 days ago
    Hi All,
    I am trying to filter an Atlas 6.1 report by excluding more than 1 value for a column. I tried using the NOT EQUAL (!=) operator on a single value and it works just fine, however, it does not work if I want to exclude multiple values. It however, works if I include multiple values in the filter, but that will not work in the long run as I would have to keep adding new values in, thus, excluding 2 out of 100 is way quicker than including 98 out of 100.
    e.g. !=ABC,!=DEF does not work, !=ABC,DEF does not work, !=ABC||!=DEF does not work, !=ABC||DEF does not work as well.
    Is there a specific way to code it?
    Thanks!
    Daren Teng
    Data Analyst | Business Intelligence Specialist
  • 2.  RE: Atlas 6.1 Filtering
    Posted 18 days ago
    If you want to pass a value to Atlas, you don't need the equals sign. This works just fine:
    Guy Terry
  • 3.  RE: Atlas 6.1 Filtering
    Posted 16 days ago
    Thank you, this works fine!
    Daren Teng
    AGI-MFS/YORK/STORMOR/BROWNIE
    Grand Island
  • 4.  RE: Atlas 6.1 Filtering
    Posted 18 days ago
    Edited by Steve Latta 18 days ago
    You don't need the = sign. Just format like this:
    !ABC,!DEF,!GHI
    You can even mix with values you want:
    A..F,!D..E
    Which would return A,B,C,F.
    Steve Latta
    Accountant
    Ortec, Inc.
    Easley SC
  • 5.  RE: Atlas 6.1 Filtering
    Posted 18 days ago
    Daren,
    You should be able to use !ABC,!DEF
    Amy Akley
    Sr. Financial System Analyst
    XTRA Lease
    Saint Louis MO
  • 6.  RE: Atlas 6.1 Filtering
    Posted 18 days ago
    ​Daren,
    Try your first option again, and this time remove the "=' signs.
    !ABC,!DEF
    I am currently on 6.1 and frequently filter in this manner.
    Matt McMains
    Stauffer's Biscuit Company
    York PA
