Edit Procurement category in Purchase requisition form in AX 2012 R3
  • 1.  Edit Procurement category in Purchase requisition form in AX 2012 R3
    Posted 18 days ago
    Hi All
    Any one have any suggestion how to make procurement category field allow to edit,
    When PR is rejected by approval as to change the procurement category, requester is unable to edit and change, requester has to reenter the line again
    please advise
    Thanks and kind regards
  • 2.  RE: Edit Procurement category in Purchase requisition form in AX 2012 R3
    Posted 17 days ago
    Hi Najeem,
    I do not think their is a way to modify the line category once it has been submitted.
    Michael Mills
    AX D365 Sr. Enterprise Consultant Operations
    Blue Horseshoe Solutions
    Carmel, IN
  • 3.  RE: Edit Procurement category in Purchase requisition form in AX 2012 R3
    Posted 17 days ago
    do you work with itemnumbers ?
    I just checked, if working with items for the requistion, the categroy is pulled from the item.
    Even upon creation of requistion you can't change. If you go to the table in AOT you can .. so must be somthinh g in the form.
    Guess a programmer can help you
    Pirmin
    Pirmin Bercher
    CARBOGEN AMCIS
    Aarau
  • 4.  RE: Edit Procurement category in Purchase requisition form in AX 2012 R3
    Posted 17 days ago
    Hi Pirmin
    Nope not  using Item numbers, using procurement category under PIM module linked with posting under IM module
    Correct you are right need some touch up in AOT, looking for some tech person feed back in which area to make it editable
    thanks and kind regards
