D365 FO - Missing workspace under Workspaces ( (Navigation pane)
  • 1.  D365 FO - Missing workspace under Workspaces ( (Navigation pane)
    Hi All,
    I created new custom workspace with development and i added under a menu.But I can't see it under Workspaces (Navigation pane).
    How can i add it ? Is there any property about that ?
    Thanks and Best Regards.
    Secil
    Secil Tuncoz
    Fahrrad XXL Group
    Frankfurt am Main
  • 2.  RE: D365 FO - Missing workspace under Workspaces ( (Navigation pane)
    Hi Secil.
    Did you build your full model and also performed a database sync? Are you logged in as system administrator? If not, you might have missed to add the workspace to the security objects. Also check if there is a confguration key linked to this workspace and if the configuration is enabled.
  • 3.  RE: D365 FO - Missing workspace under Workspaces ( (Navigation pane)
    Secil,
    Did you create an extension to the navpanemenu object and create a new MenuElementSubMenu object?
    Do you have the Menu Item Type and Name parameters on this MenuElementSubMenu associated to your created workspace element?
    Is the Visible property of this object set to Yes?
    Here is an example of how to set it up:
  • 4.  RE: D365 FO - Missing workspace under Workspaces ( (Navigation pane)
    Posted 7 days ago
    Edited by Secil Tuncoz 7 days ago
    Hi ,
    Thank you  both so much for reply.I forgot to add to navpanemenu .It is working now.
    Best Regards,
    Secil Tuncoz.
    Secil Tuncoz
    Fahrrad XXL Group
    Frankfurt am Main
