NonConformances
  • 1.  NonConformances
    Posted May 28, 2019 10:18 AM
    Today, we don't use Quality Management, however, we have a business unit that is exploring the possibility of using non-conformance functionality.  I understand Quality Management needs to be turned on, however, they don't want to use quarantine or quality orders.  The purpose is strictly for internal tracking and reporting, rather than using Excel to manage the tracking and reporting.
    Set-up:
    • Quarantine and Quality number sequences will not be assigned
    • NonConformance number sequence assigned
    • Will create a wide variety of Problem Types
    Are there financial impacts that we need to be aware of if we simply want to use non-conformances for reporting purposes?
    Thank you for your responses in advance!
    Erick Stebbings
    Senior ERP Process Leader
  • 2.  RE: NonConformances
    Posted May 29, 2019 07:47 AM
    No there is no financial impact based on your described . If you were using quality orders and changing statuses of inventory based on the quality order results  there might be financial impacts but again there would be no GL postings. In your example of just using non-conformance no impact at all.   You might want to look at corrective actions that you can preform with non-conformance functionality.
    Michael Mills
    Blue Horseshoe Solutions
    Carmel, IN
  • 3.  RE: NonConformances
    D365UG/CRMUG ALL STAR
    Posted May 29, 2019 08:04 AM
    That is exactly how we use the non-conformance in quality management.  We use the function more to guide us to what needs to be trained better, or processes that need to be reviewed.  We are a manufacturing facility, and have multiple instances that we want to document a finding.  We use the system to document any internal issues.  If the fault can be named, it is named, if not, it is still documented to future improvement if patterns can be found.  Since we are using it for documenting an incident, to us, the most important factor is that we can see the impact on a per order basis.  So, we have not had a need to use the other function of quality management at this time.
    We do like the approval process in non-conformances.  We have supervisors review all non-conformances every week and approve them as being breaks in process by a team member if appropriate.  This is what guides our training and process review schedules.
    Jennifer Codding
    Senior IT Business Analyst
    CMC Group
    Bowling Green OH
