Hi Alaadin,
I have seen this issue too. I can't remember which release but there was a hotfix for a mobile menu item where you can register serial numbers at the RAF process in the mobile device. The caveat is the serial numbers themselves must already exist in AX. So they would have to be created already, then chosen in the mobile device at time of RAF.
eBECS
Atlanta GA
Sent: 04-18-2018 07:34 AM
Subject: Dynamics 365 F&O Warehouse App function
<main id="Main" data-grid="container" ms="" cmpgrp="body" data-bi-area="body">Hello,
Concerning Dyn365F&O warehouse app; If a production product is tracked by serial number, and the serial number assignment is set to "manual" under tracking number groups setup, then it is not possible to report the product as finished in the WHS app (the app doesn't allow to enter and create new serial numbers, it only allows to enter pre-generated ones or automatically assign a new ones), any workaround for this case to allow the manual serial through the app?
</main>
Alaadin
