Purchase Requisition Questions
  • 1.  Purchase Requisition Questions
    Posted 17 days ago
    Good day!
    We are trying to give users read only rights to purchase requisitions or figure out a way to get the approval documents that are attached at the requisition level to be viewable at the purchase order level. Any help with this would be great!
    Thanks!!
    Carlyle Lockhart
    Vista Proppants and Logistics
    Fort Worth TX
  • 2.  RE: Purchase Requisition Questions
    Posted 17 days ago
    Hi Carlyle,
    There are privileges in the security configuration settings that should help with that. I haven't tested it myself, but it seems to me that it should work if you create a duty and/or role (or assign to an existing role that does not have edit access to purchase requisitions):
    - View purchase requisition headers
    - View purchase requisition lines
    Any attachment to purchase requisitions should be visible by granting view-access to the header and lines.
    Kerstin Newman
  • 3.  RE: Purchase Requisition Questions
    Thanks for the reply! I will test this and post back here. I appreciate it!
    Carlyle Lockhart
    Fort Worth TX
  • 4.  RE: Purchase Requisition Questions
    Kerstin,
    Thanks for the information. I just tested the rights that you suggested - but still no go. I have uploaded the privileges and duties that I have assigned. I started off with just the base system user as a duplicated role. Any other pointers - please let me know. Thanks!
    Carlyle Lockhart
    Fort Worth TX
  • 5.  RE: Purchase Requisition Questions
    I just did some testing myself, seems a little more complicated, but doable:
    - Create an employee/worker record for the user and link to the user record
    - Provide privilege "maintain all purchase requisitions" to the user
    - Create new privilege that has a Action menu items "PurchReqCreatePurch_Action" set to Deny for update, create, and delete and assign to user
    I have tested this and I can view all purchase reqisitions but not create or update anything on the purchase requisition screen - however I was able to delete or add new attachments, I am not sure if that is something you would want to restrict as well? If so, I am not sure how to do that as it seems to be a general "document handling" privilege that might not just apply to attachments on this screen but all document attachments in the whole system.
    Kerstin Newman
  • 6.  RE: Purchase Requisition Questions
    Posted 10 days ago
    I will be testing this shortly. Thanks for this!!
    Carlyle Lockhart
    Fort Worth TX
  • 7.  RE: Purchase Requisition Questions
    Posted 10 days ago
    I tested this out, and worked perfectly. Thanks for all of your help with this! Have a great day!!
    Carlyle Lockhart
    Fort Worth TX
