Management reporter does not show new budget transactions.
  • 1.  Management reporter does not show new budget transactions.
    Posted Mar 12, 2019 02:07 PM
    I have recently loaded the new budget transactions using DIXF and while they appear correctly in AX in the budget register, they do not appear.
    I have run the budget report and no data was returned and then we run the expense data, the expense fields show values, but the plan budget amounts do not.
    Where can I look to see if the data is present?  What can I do to get the data where it needs to be.  We did just follow the database refresh procedure.
    Rich Wasson
    Senior Developer
    Fishers OH
  • 2.  RE: Management reporter does not show new budget transactions.
    Posted Mar 13, 2019 10:18 AM
    issue turned out to be the import file for DIXF included the TransactionCurrencyAmount, but not the AccountingCurrencyAmount.  MR, uses the latter field (though the form uses the other).  After correcting this and refreshing MR, this fixed the issue.
    Rich Wasson
    Senior Developer
    Fishers OH
