BYOD - Data export failing for a single data entity
  • 1.  BYOD - Data export failing for a single data entity
    Posted Feb 28, 2020 11:25 AM
    I'm currently running to an error when I try to export a data entity to our BYOD.  I'm getting the following error message
    Log Text
    Export Execution failed for entity Sales invoice lines:Export failed while copying data from staging to destination
    Info log
    An error occurred in add data flow component for entity store
    Currently I have over 20 data entities that I'm exporting to BYOD and they are exporting without any errors.  I have tried republishing this data entity multiple times but I continue to get this same error.  I have compared the entity schema to the destination and they match.  I have tried incremental only and full push only and I have tried running it interactively and in batch.
    Any suggestions on other things I can look at to troubleshoot this error?
    Mike Everingham
    #FinanceandOperations
    Michael Everingham
    The Cellular Connection
    Carmel IN
  • 2.  RE: BYOD - Data export failing for a single data entity
    Posted Feb 28, 2020 11:56 AM
    Hey Mike;
    Curious on the release that you are running...
    We had an issue with "Sales Invoice Headers V2" on an export to BYOD aftyer we migrated to 10.0.7 for which we opened a SEV-A Ticket with MS (120012621000151 Sales Invoice Headers V2 Export to BYOD Failed)...
    We spent a "long weekend" troubleshooting and debugging this entity as it supports multiple 3rd party extracts and internal dashboards...
    In the end, we reverted the use of the 10.0.4 entity...  MS openly admitted that the construct of the 10.0.7 entity was an error and was missed in the QA process...
    Joe MacPherson
    Coldwater Creek
    Hingham MA
  • 3.  RE: BYOD - Data export failing for a single data entity
    Posted Feb 28, 2020 02:09 PM
    Hello Joe
    We just migrated from 10.0.4 to 10.0.8 last weekend.
    How did you revert back to the 10.0.4 entity after you had moved to a newer version?  Did you have to roll back the update?  Fortunately this is only in our sandbox environment as we are building out integrations in preparation for going live this summer but I don't want to wait too long to get this fix.
    Mike
    Michael Everingham
    Carmel IN
  • 4.  RE: BYOD - Data export failing for a single data entity
    Posted Feb 28, 2020 03:22 PM
    Hey Michael...
    There is a 'trick' to be able to gain access to the prior release Data Management Entity...
    See the attached...
    Joe MacPherson
    Coldwater Creek
    Hingham MA
    Attachment(s)
    docx
    Previous Entity Access.docx   323 KB 1 version
  • 5.  RE: BYOD - Data export failing for a single data entity
    Posted Feb 28, 2020 04:54 PM
    Thanks Joe
    I'll give this a try
    Mike
    Michael Everingham
    Carmel IN
  • 6.  RE: BYOD - Data export failing for a single data entity
    Posted Mar 02, 2020 11:27 AM
    Mike,
    We have seen the below additional steps fix the issue at times when there were significant changes to an entity (like a PK change etc). We use custom entities so I can't confirm this resolved any OOB entity issues.
    Delete the entity from all export/import projects (not the run history, just the projects)
    Delete the entity from Data entity list
    Refresh Entity List to restore the data entity to list
    Check the entity mapping for disabled config key fields and remove them/save mapping
    Republish the entity and test full push export first
    Mike
    Michael Burt
    Solution Delivery Manager, BI & Analytics
    Arbela Technologies
    Irvine CA
