Unsuspend a cost center in AX 2012
  • 1.  Unsuspend a cost center in AX 2012
    Posted May 25, 2020 10:53 PM
    How do I "unsuspend" a cost center?
    I looked up the cost centre general ledger \ setup \ organisation \ cost centers and clicked on editing it, but there's nothing in there to show that it's suspended or a tick box to untick to unsuspend it.
    Thank you!
    Ethel
    Ethel Cueto
    Financial Controller
    Ultimate Positioning Group
  • 2.  RE: Unsuspend a cost center in AX 2012
    Posted May 26, 2020 09:44 AM
    For general ledger financial dimensions, you need to look into the Financial dimension menu. This is where you can suspend cost centers for posting. I don't have a ax 2012 environment to show you, but pretty sure the menu is under general ledger>setup and then financial dimensions.
    Juan Sebastian Grijalba
    Berkowitz Pollack Brant
    Miami
  • 3.  RE: Unsuspend a cost center in AX 2012
    Posted May 26, 2020 06:27 PM
    Hi Juan,
    Thank you! I found it under the link you provided.
    Much appreciated. ;)
    Ethel
    Ethel Cueto
  • 4.  RE: Unsuspend a cost center in AX 2012
    Posted May 27, 2020 02:13 AM
    Hello Ethel,
    just switched the "Suspended" button to NO and it will worked
    Dinabandhu Mohapatra
    Functional LeadIndia
  • 5.  RE: Unsuspend a cost center in AX 2012
    Posted 18 days ago
    Ethel:
    I believe you are referring to the Financial Dimension "Center".  The quickest way to get there is open a form like General Journal select the Financial Dimensions tab, right-click in the Center field and select View Details.  This will bring up your Financial Dimension Values, you will see in the General section a Suspended check box...
    Screen Shot 1
    Screen Shot 2
    Dan Murphy
    Special Projects
    Flexaust
    San Diego CA
