  • 1.  Correcting item price on purchase order invoice
    Posted Oct 07, 2020 01:15 PM
    Edited by Aybike Turk Oct 07, 2020 01:15 PM
    Hi all,
    I have multiple purchase orders that includes an item with the wrong price (16,500 instead of 13,500). Unfortunately it's been received and invoiced. Since the PO is confirmed and invoiced, I cannot add a new line to it.
    What can I do to fix this issue? Create a return order and create a new PO with the updated price? Is there a better way since I have a lot of POs to correct?
    #Functional #DeploymentandImplementation
    Aybike
  • 2.  RE: Correcting item price on purchase order invoice
    Posted Oct 08, 2020 07:57 AM
    Hi Aybike
    I believe you can add a line to an Invoiced PO, it will ask you if you are sure you want to edit and you can say yes.
    Alternatively create 1 PO for all the errored lines you have and just put the total quantity you need to rectify on that PO, that will allow you to save time.
    Arush Kuthiala
    Western Computer
    Toronto ON
  • 3.  RE: Correcting item price on purchase order invoice
    Posted Oct 08, 2020 08:47 AM
    Edited by Aybike Turk Oct 08, 2020 12:42 PM
    Thank you for your response Arush. Add line field is grayed out so I cannot add anything else to the PO.
    About your second suggestion, are you saying I could create a PO for that item specifically as a credit line? Or just for the difference which is -$3000?
    Thank you!
    Aybike
  • 4.  RE: Correcting item price on purchase order invoice
    Posted Oct 08, 2020 09:29 AM
    Edited by Ian Gorman Oct 08, 2020 10:31 AM
    Procurement and sourcing parameter 'security level of invoiced orders' controls the functionality of editing an invoiced PO.
    Aybike - You're going to want to leverage the negative line POs for correcting these types of mistakes. What costing method are the items that came in at the wrong financial price?
    Ian Gorman, PMP, MCSE
  • 5.  RE: Correcting item price on purchase order invoice
    Posted Oct 08, 2020 12:41 PM
    Edited by Aybike Turk Oct 08, 2020 12:41 PM
    Thanks Ian! I checked the security level of invoiced orders and it's set to None, but I am still unable to add new lines on the invoiced order.
    The item I need to fix has FIFO on it. I could return it and create a new PO with the correct price but that will take too long since I have so many wrongly invoiced POs. Any other thoughts to go about this?
    Thanks!
    Aybike
  • 6.  RE: Correcting item price on purchase order invoice
    Posted Oct 08, 2020 01:01 PM
    Edited by Ian Gorman Oct 08, 2020 01:02 PM
    Strange. If you're a sys admin and still cannot add lines, then you most likely have change management turned on. That can throw a wrench in the editing of POs that are invoiced.
    Yes, technically you can use the on-hand inventory or transaction adjustment:
    Inventory Closing in Dynamics 365 for Finance and Operations | SherWeb
    https://docs.microsoft.com/en-us/learn/modules/configure-inventory-management-dyn365-supply-chain-mgmt/17-invent-close-adjust
    You just want to ensure this is fully tested in UAT before bringing it over to PROD.
