ISO20022 Credit Transfer (GB)
Jump to Best Answer
  • 1.  ISO20022 Credit Transfer (GB)
    Posted 9 days ago
    After refreshing my sandbox environment. I had to delete ISO20022 Credit Transfer from the sandbox environment and try to reimport them.
    I am running into an issue with the ones below when I try to import as I am trying to ensure that the version in my sandbox mirrors that of production.
    ISO20022 Credit Transfer (GB) version 19.19.4
    ISO20022 Credit Transfer (IE)   version  19.20.3
    On import, both fail with the below message
    Property 'ParmComponent' of class 'ERFormatComponentPropertyBinding' should be serialized by reference only. Check process stopped. Turn on the ER user parameter 'Continue configurations consistency check while errors found' to save changes in such cases and continue check process for other configurations.
    For ISO20022 Credit Transfer (GB) I tried version 19.19.5 and it imported successfully. When I try to add the SEPA  bank file from production to ISO20022 Credit Transfer (GB) I am met with the error below
    Electronic reporting unresolved reference left Reference of the object 'SEPA GBR' to object 'Base'
    Does anyone have an idea how I can get this fixed?
    Kamar Wilks
    BlueCrest Inc
    Danbury
  • 2.  RE: ISO20022 Credit Transfer (GB)
    Best Answer
    Posted 4 days ago
    Just in case someone else runs into this issue
    If the configuration was created on a version earlier than 10.0.9, I am testing on 10.013, then we will get errors due to a bug in the system. The issue should be solved by manually updating the ER config file format. Microsoft was able to provide updated config files to resolve the issue.
    Kamar Wilks
    BlueCrest Inc
    Danbury
