Master Scheduling Deadlock Errors
  • 1.  Master Scheduling Deadlock Errors
    Occasionally, I am getting the following error message from running Master scheduling which is run as a batch job during the night;
    Cannot select a record in Net requirements (ReqTrans).
    Deadlock, where one or more users have simultaneously locked the whole table or part of it.
    I was getting this error when I originally made use of 8 helpers, but reducing this to 0 seemed to resolve the issue, however it has begun to reoccur. There doesn't appear to be an issue with the item setup as I can manually run master scheduling without error.
    Has anyone else encountered this issue and is there a workaround or a solution?
    I'm thinking that the code needs amending to include Try..catch..retry keywords.
    Paul Fildes
    Steelite International Ltd
    Stoke-On-Trent
  • 2.  RE: Master Scheduling Deadlock Errors
    Hi Paul,
    Which exact version of AX 2012 are you using? Have you searched LCS for a potential known issue?
  • 3.  RE: Master Scheduling Deadlock Errors
    Posted 10 days ago
    We have had similar issues, getting worse and worse over time, mainly when using helpers, but also occasionally without helpers. Below some of the actions we have taken, to solve the issue :
    Custom code
    Re-design custom code in class\ReqCalc Note: Part 1 (updating fields)
    Clean orphan data
    SQL job to clean up Orphan data
    PAGE lock (REQ)
    Disable PAGE lock for Main REQ tables
    New Index
    New Index creation on ReqTransTable
    Circularity checks
    Clean systematically circularity checks
    PAGE lock (Batch)
    Disable PAGE lock for Main Batch tables
    PAGE lock (ReqLog)
    Disable PAGE lock for ReqLog
    For us the sum of these actions solved the issues. Good luck
    Patricia Liekens
    Lantmännen Unibake Holding A/S
    Copenhagen
