Error in changing status of an AR invoice
  • 1.  Error in changing status of an AR invoice
    Posted 22 days ago
    We have this error when changing status as promise to pay / disputed against an AR invoice in AX 2012.
    "Cannot create a record in Activities (smmActivities). Activity number: AC000019, Change status. The record already exists."
    Would anyone know how to fix this?
    Thank you in advannce!
    Ethel Cueto
    Financial Controller
    Ultimate Positioning Group
    Brisbane, Australia
  • 2.  RE: Error in changing status of an AR invoice
    Posted 22 days ago
    Dear Ethel,
    This looks like a number sequence issue.
    Can you please find the number sequence used for the activities and check the status list?
    Thank you
    Bianca
    Bianca Vlad
    SAGLOBAL
  • 3.  RE: Error in changing status of an AR invoice
    Posted 22 days ago
    Hi Ethel,
    I agree with Bianca, this looks to be an issue with the number sequence.
    Typically when I see this sort of issue, there's a value stuck in the status list for the number sequence in question.
    1. Identify the number sequence that is related to the activity.
    2. Navigate to Organization Administration>Common>Number sequences>Number sequences, then find the sequence in the list.
    3. Click Status list from the Administration area of the Ribbon (see attached photo)
    4. Select any values the resulting table, then select File>Delete.
    This should resolve the issue.
    Status list location
    Josh Bazin, CPA, CMA
    (they/them)
    Functional Analyst, NTT DATA
    Edmonton AB
  • 4.  RE: Error in changing status of an AR invoice
    Posted 19 days ago
    Thank you Bianca and Josh.
    I will check which number sequence this activity relates to.
    Ethel
    Ethel Cueto
    Brisbane, Australia
