Customer unit of measure requests
  • 1.  Customer unit of measure requests
    Posted Feb 08, 2019 03:39 PM
    As of lately it seems that more and more customers are requesting their invoices to be in specific units of measure for their business. Has anyone run into this and if so, how do you go about making those types of changes in D365?
    We've tried this for one customer so far and created a new unit of measure, the problem is that all reports that we run internally now show in this "non-standard" UoM, so it requires converting to what our standard is.
    Justin Cooper
  • 2.  RE: Customer unit of measure requests
    Posted Feb 11, 2019 01:47 PM
    ​A quick review of UOM design in AX:
    Each product has 3 UOM defaults, one for Sales, one for Inventory, and one for Purchasing. Sales and Purchasing UOMs require a conversion factor to the Inventory UOM. This allows the system to perform internal tracking in the Inventory UOM, while handling sales and purchase orders in alternate UOMs.
    Thus, a customer requesting a different UOM should just involve ensuring that customer's orders are taken in their desired UOM.
    The problem is often in custom reports not handling this cleanly because the programmer didn't expect the UOM to matter. Customer facing reports should always try to display in the saleline's sales unit of measure - and Qty values should be converted to that UOM, or use the sales qty field if available. Internal reports should always work off the inventory UOM and Qty's.
    The one weak point - there isn't any good way to enforce a customer's choice of sales UOM. However - if you are using trade agreements, you can take advantage of the fact that the price in the trade agreement has to match the sales UOM on the line in order to pull the price back. Thus, you can put some ridiculous pricing in the trade agreements using the UOMs that are not allowed, to ensure the order is obviously incorrect if the order entry person doesn't pick the right UOM.
    Tony Zeigler
  • 3.  RE: Customer unit of measure requests
    Posted Feb 18, 2019 09:08 AM
    Hi Tony,
    Thank you for your reply on this! We problem we are running into is a customer requesting a different UoM that is quite unique - typically our UoM is in length measures. They are requesting it to be in weight. The problem with this is that each product is a bit different when it comes to weight. No quite sure how to handle this as it sounds like we would have to create a UoM for each of the different products of different weights...
    Thank you
    Justin Cooper
    Justin Cooper
  • 4.  RE: Customer unit of measure requests
    Posted Feb 18, 2019 01:22 PM
    ​Ah yes, we have a lot of clients in the forest products space, and it is painful. Pre-2012 R3, AX didn't even have UOM conversions specific to a product variant, so for one client we had to do a massive mod to add that. And now it's out of the box :)
    But - getting the data into the system is still troublesome. We had one client that had rules for it that they built into their 3rd party configurator, and then had it add the conversions when it created the variant. Other clients put the work on their product engineers - each product they define they have to include the needed UOM conversions for.
    One thing I did find - if the conversion doesn't exist - it can prevent the user from saving the salesline correctly. So there was some discussion about having a generic conversion in place that was unrealistic, so the sales entry staff could enter the order correctly, then call out to product engineer to give it a correct conversion, then confirming the order after it was corrected. However, this can be risky as well, because it does open up the possibility of sending out an order with a bad conversion.
    You can also consider having the sales staff put the order on hold with a hold code representing the need for a UOM conversion, have the engineers get an alert when such a hold is created, and they have a process for responding to the alert by fixing it and releasing the hold. This then allows the order to progress.
    If the product engineers have rules they can use to define the conversions, they may be able to upload an excel into the UOM conversion table that loads all the conversions.
    Hopefully you don't have the issue that lumber can have - a wet weight and a dry weight :)
    Tony Zeigler
  • 5.  RE: Customer unit of measure requests
    Posted Feb 18, 2019 04:57 PM
    Hi Justin,
    Have you looked into the catch weight functionality to see if that could be used to meet the requirements?
    Cheers
    Phil
    Phil Dawson
    Data#3 Limited
    Toowong
  • 6.  RE: Customer unit of measure requests
    Hi Phil,
    Appreciate the response and apologies for my delay.
    This has been coming up more and more as of recently. We have more customers requesting that their invoices reflect a different UoM than what our standard is. We have explored doing the conversions but one of the issues is that these are one-off requests, so it requires the CS team to keep track and enter orders accordingly.
    We have not looked at the catch weight function - do you have any reference links as to what exactly this is?
    Justin Cooper
  • 7.  RE: Customer unit of measure requests
    ​If your just dealing with one-off requests, I don't think Catch weight will help much - it's quite intrusive to turn on & use.
    The best way to catch one-off issues during order entry is to have a closed loop agreement with your customer. Ie., send them that confirmation document and make sure they review it :) That way if issues do come up, they can't blame just you ;-)
    Tony Zeigler
  • 8.  RE: Customer unit of measure requests
    Hey Tony,
    Appreciate the response! I am not sure what has been going on as of lately, but we have more and more customers requesting one-off UoMs on their invoices over the last couple of weeks. We want to meet their needs, but having to go in and create these unit conversions for individual customers would be a nightmare to maintain. I was hoping that there would be an easier way to do it.
    Justin Cooper
  • 9.  RE: Customer unit of measure requests
    ​Unfortunately, there is no good solution out of the box for dealing with just occasional customer requested UOM conversions.
    The cleanest solution would probably be a custom button on the salesform that would allow order entry staff to quickly add one, then they could use it on the salesline. The button would just need to create a modal pop-up that takes an item, then use it to open the standard UOM conversion form. However, it would all be custom. You would probably have to work out security permissions on the usage of it - and you might want to enable some of the audit fields on the UOM conversions if your opening it up to a large group. A good dev could probably complete such a customization in a couple days or less.
    Normal processes would be:
    1. Product engineering group creates standard UOM conversions when they define a product.
    2. Configuration tool calculates standard UOM conversions when it defines a product.
    3. Engineering group uses spreadsheets to load updated conversions on a periodic basis for conversions that change over time.
    4. Catch weight is enabled, which at a very high level, allows you to track inventory qty at the batch or serial dimension, separate from the sales uom. This allows you to separate qty of packages from qty used for invoicing. Use cases are limited - so it should only be used in the scenarios that really call for it.
    Tony Zeigler
  • 10.  RE: Customer unit of measure requests
    ​we had request for multiple unit of measures for 'inventory unit', which we handled thru custom code. Still wondering why Microsoft does not allow multiple uom for inventory transactions.
    i believe my msg is relevant in this discussion as its about uom and how to handle different business requirements.
    Amer MS
  • 11.  RE: Customer unit of measure requests
    ​Multiple inventory units of measure would simply be too complicated to support in a general way.
    The inventory unit of measure should be the smallest unit of an item you track in inventory.
    The sales & purchase units of measure are simply defaults for buying and selling.
    So for instance, you may track individual items in inventory (ea), but buy in cases, and sell in boxes.
    However, these can be thought of as simply "views" of inventory that is tracked in the inventory unit of measure.
    Any additional units of measure needed can probably also be thought of as "views".
    For instance, in the lumber products industry, we often talk about MBF (Million Board feet), as well as pieces. So for some of our clients we customized an alternate unit of measure for the salesline so a salesperson can quickly see/enter in either pcs or mbf. However, those are still converted to the inventory unit of measure, and need to have conversions between the different views. So inventory is tracked in pcs.
    In summary, when dealing with units of measure - your inventory unit of measure is most important - and should be the smallest trackable unit when counting/moving inventory. All others should be considered views upon that inventory unit of measure.
    Tony Zeigler
  • 12.  RE: Customer unit of measure requests
    Thanks Tony.  I agree with your point that other uom are just views, which we too accomplish with some customization for certain transactions. we were expecting this as standard across system, because business works with multiple units. For example, lowest unit of inventory is pieces but transfer happen in pallets, production happen in cases and sales can be in cases or pieces. User finds it difficult to enter 181440 pieces when they are transferring 18 pallets, where each pallet has 120 cases of 84 pieces each.
    lets raise this in ideas to Microsoft
    Amer MS
  • 13.  RE: Customer unit of measure requests
    ​I'm going to disagree with Tony a little bit. Your inventory unit of measure should be the unit that makes sense to your business, which isn't necessarily the smallest. Your default conversions should take care of any transactions, selling or inventory, in alternate units of measure whether larger or smaller, as well as allowing you to view your inventory in terms of those alternate units of measure.
    We are a chemical manufacturer. The vast majority of our inventory raw material and finished goods, whether liquid or dry, is tracked in pounds. That said, we sell to a lot of companies who buy from us in grams or kilograms, and many of those customers have specific levels of precision they require.
    So, for example, we have conversions set up where:
    KG1 = 1 kg = 2.2 lbs. (1 decimal place)
    KG3 = 1 kg = 2.204 lbs. (3 decimal places)
    KG4 = 1 kg = 2.2046 lbs. (4 decimal places)
    KG8 = 1 kg = 2.20462262 lbs. (8 decimal places)
    The gap, for us anyway, is that there's no way in AX 2012 to define a default selling unit of measure per customer. That has to be done at the item level. One way to deal with it may be to set up your items for manufacturing and inventory with one item key and create a separate item key for that item/customer combination with their default selling unit of measure set? You'd need some way pull the inventory from one item key and sell it as the other. I don't know if there's any way to do that without a manufacturing step. Maybe others can suggest something?
    Example:
    Widget01 is the manufactured/inventoried product with all units of measure in LBS
    Widget01-001 is the same product, for customer 001, with a selling UOM of KG1
    Widget-01-005 is the same product, for customer 005, with a selling UOM of KG4
    Somehow you'd need a step in there to take 2.2 units of Widget01 out of inventory and sell it as 1 unit of Widget01-001 and take 2.2046 units of Widget01 out and sell it as 1 unit of Widget01-005. I'm on the accounting side of things, so I don't know if there's a simple way to do that without actually manufacturing the alternate item key product first.
    Without a little more detail about your unit conversion needs, it's kind of hard to understand how you are ending up with so many unique conversion requirements for each customer instead of a few that can be used across all customers.
    Steve Latta
    Accountant
    Ortec, Inc.
    Easley SC
  • 14.  RE: Customer unit of measure requests
    The approach I've used was to use a combination of Customer Item description (use as the SO item lookup reference to the AX item id: some modification was required) and Trade Agreement Sales price (to assign the customer UOM). We required POs from the customer to use their item number.
    Mark Prouty
    Programmer / Analyst
    ANGI Energy Systems
    Janesville WI
  • 15.  RE: Customer unit of measure requests
    one note, on the smallest unit , and the makes sense unit. Remember that for example if you buy in rolls and store in rolls  and your conversion is 1 roll equals 50000 yards, and your bom consumption is in inches, you will get some 0 consumptions and 0 cost as you do production. so I caution make sure that you use appropriate units to not give misleading results in the system so for the above I would buy in roll store in yds
    and consume in inches or feet. then everything works.
    Paul Martin
    Production Program Manager
    Elite Comfort Solutions, LLC
    Rutherfordton NC
