Renumbering PO Lines
  • 1.  Renumbering PO Lines
    Posted Nov 29, 2019 05:30 AM
    ​Dear all,
    this is a little thing, but when I firm order lines from planned orders I would prefer that the order lines in the created order are sorted according to requested ship date.
    Is there a way to do this? Either in the process of firming or afterwards to renumber the lines according to a date?
    Per Frimann
    Purchasing
    PMC Hydraulics
  • 2.  RE: Renumbering PO Lines
    Posted Dec 05, 2019 06:17 AM
    Hi Per,
    There is an option for renumbering or change it manually. There is no automation to renumber based on the delivery date. You can consider a customization for this.
  • 3.  RE: Renumbering PO Lines
    Posted Dec 06, 2019 02:21 AM
    Hi André,
    I'm very pleased to hear that there is a way to do this. Any chance that you could tell me how to?
    Per Frimann
    Purchasing
    PMC Hydraulics
  • 4.  RE: Renumbering PO Lines
    Posted Dec 16, 2019 04:08 PM
    Hi Per,
    Apologies for a late answer. The line number itself can be changed manually. If you have changed a lot of lines, you can also use the option 'Renumber' from the Update line menu. This will recreate the line numbers based on the configuration. E.g. steps per 10.
  • 5.  RE: Renumbering PO Lines
    Posted Dec 17, 2019 07:56 AM
    Please note what was said is you can certainly renumber the lines, but to do it by dates would be either manually, or by doing a customization. all the renumber does is change the line numbers to be sequential, but not by any other criteria.
    Paul Martin
    Production Program Manager
    Elite Comfort Solutions, LLC
    Rutherfordton NC
  • 6.  RE: Renumbering PO Lines
    Posted Dec 17, 2019 02:55 PM
    Hi André and Paul,
    so is there a way to sort the lines by a criteria like the date so you don't have to do it manually?
    Best regards
    Per
    Per Frimann
    Purchasing
    PMC Hydraulics
  • 7.  RE: Renumbering PO Lines
    Posted Dec 17, 2019 04:53 PM
    Hi Per,
    I will repeat a part of my first reply. There is no option to do it automatically based on a date. There are options to do manual updates or consider a customization.
