Quality order creation on receipt - change location
  • 1.  Quality order creation on receipt - change location
    Posted Mar 30, 2020 11:04 AM
    #​​Unified Operations
    #D365
    Creating a quality order automatically upon PO receipt works great except the location defaults to the receipt location and I can't change it. I want to receive into a DOCK location and then transfer product to the QUALITY location which is physically far away from the DOCK. Product can sit at the DOCK for some time before being moved to QUALITY and it would be preferable to know the physical location.
    Peter Craven
    Corterra Solutions
    Lisle IL
  • 2.  RE: Quality order creation on receipt - change location
    Posted Mar 30, 2020 01:18 PM
    This is a known limitation of quality orders, the Blue Horseshoe code acquisition has enhancements in this area that I believe resolve your issue, but I haven't tested in D365, I'm going off what R3 did with this code.
    What version / PU of D365 are you at?
    10.0.5 added Quality Check / QC Dock Check
    10.0.8 added more of the BHS code
    Quality check (QC dock check)
    QC dock check adds the ability to prompt users to perform a simple accept/reject quality check during inbound processing of inventory. When the quality check step is in a work template being processed, the mobile device user will be prompted check the quality of the inventory they are currently handling. The results of this test will be stored (associated with and viewable from the work line). If the quality check fails, then the current work will be cancelled, and new work will be created to take the inventory to a quality processing location. Optionally a quality order can be created when the check fails.
    Quality management for warehouse processes feature
    Quality management for warehouse processes extends the capabilities of the current quality management feature. It allows users to integrate item sampling controls into the warehouse receiving process. Work can be automatically generated to take inventory to the quality area by percentage, fixed quantity, or based on every nth license plate. Quality orders can now optionally be automatically created for the inventory being sent to the quality area and are not always required.
    Once a quality order has been completed, work will be created to take inventory to the next location in the process (quality fail, storage, etc.).
    RSM
    OH
  • 3.  RE: Quality order creation on receipt - change location
    Posted Mar 30, 2020 02:29 PM
    We are on version 10.0.8, update 32. Do the updates you referenced only effect WMS or does the functionality apply to standard warehousing as well?
    Peter Craven
    Corterra Solutions
    Lisle IL
  • 4.  RE: Quality order creation on receipt - change location
    Posted Mar 30, 2020 02:43 PM
    The quality check changes are only going to affect advanced warehousing.  I believe the additional quality management features will bring you some changes in sampling plans that might be useful, but again this is largely an advanced warehousing change.
    If you're just using basic warehousing maybe you can change your sampling plan to only create the Quality order against a qty of 1.  Then you would be able to move the remaining inventory somewhere else.
    RSM
    OH
  • 5.  RE: Quality order creation on receipt - change location
    Posted Mar 31, 2020 01:43 PM
    If you're using advanced warehousing, it's fairly easy to set up a work template that is tied to the existence of an open quality order on a purchase order line.  The separate work template gives you access to different routing and rules for handling the receipt.  It sounds like you might be using standard inventory management, which limits the toolset you have available.​
  • 6.  RE: Quality order creation on receipt - change location
    Posted Apr 01, 2020 09:56 AM
    Yes, we are using standard warehousing but it seems that advanced warehousing is calling out to us. We are trying to keep things simple but it seems that WMS may be a wiser solution than making changes to the standard warehouse solution. Another wrinkle is that this is an on-prem implementation.
    Peter Craven
    Corterra Solutions
    Lisle IL
  • 7.  RE: Quality order creation on receipt - change location
    Posted Apr 01, 2020 12:15 PM
    ​It is a very complicated module to set up, if you want to make full use of its features.  It can also be set up to operate very simply, and it simplifies a lot of the transactions in other modules.  It's worth considering, especially as an alternative to modification.
