Audit Trail
  • 1.  Audit Trail
    Is there an audit trail option for any changes to setting?
    Jennifer Vanselow
    Augeo Affinity Marketing
    St. Paul MN
  • 2.  RE: Audit Trail
    In a sense, yes. What version of AX are you running?
    https://docs.microsoft.com/en-us/dynamicsax-2012/appuser-itpro/configure-and-manage-database-logging
    Ian Gorman, PMP, MCSE
    Consultant
  • 3.  RE: Audit Trail
    Jennifer,
    The Database Log is Microsoft's answer for an audit trail solution in AX. It's meant as more of a debugging tool rather than a full on audit solution and will affect system performance when it is enabled on a table. So you want to be sure you do not turn it on for transactional tables. Reporting on the audited data can be cubersome and there is also no data management of the audited data (archiving/purging) so something else to keep in mind. If you are looking for a more full fledged audit solution there are other ISV options.
